XM Commander question
ok... so i have searched all over the forum and i havnt been able to find any pics of the xm commander installed on a new f150 without the center shifter. im trying to see if it will fit in the area where the cigar lighter is now. any pics or ideas would be appreciated.
I didn't flush mount mine as I didn't want to wreck the stock trim panel. Also why I pulled the wire through the joint instead of cutting through the lighter trim. at the angle it sits in the truck, you can't see the wire unless you're looking for it. But yes, that's the perfect spot for a commander. I used foam tape to make everything level with the rim of the lighter socket, then velcro taped to that.
Good antenna install spot is to go through the 3rd brake light, but wrap the wire around the light (there's a little lip on the outside of the light before the seal which covers the wire & holds it fine) and only put the wire under the seal in the bottom middle of the light so you won't encourage any leaks.
How's this:
How's this:
Thanks for all the replies i went out today and bought the commander and installed it, everything works and sounds great! hopefully i will have time this weekend to throw some pics up of my truck.
