Volant C.A.I. Reliability
Do they give you a cover for the snorkle hole if you dont get it right away?? Also will the snorkle improve the air flow or has it a different purpose? lonuf truck looks good. My wife's asleep should look now LOL.
i did the install. i wanted te pipes to line up with the wheel well but they were about an inch short. plus i had to cut them back cause the tips stuck out about 2" when i was done. but im very happy with the look
as for drone. i do have a little. mostly from the intake. but its nothing i cant deal with. gets loud when you open up that back window riding next to someone. makes me wonder how loud it is at WOT passing someone with their window down.
Just seen the thread where air raid may have a lean burn issue. People with the Volant installed for a long time answer up please. Have any of you had a engine lite from the volant. Giving you a lean burn in codes?? As other member stated it's a expensive engine to rebuild if Ford denies the warranty.
