AUX input harness available yet?
I know this has been discussed to death, but hopefully someone has an update..... is there a wiring harness available so that we can connect RCA connectors to the AUX input (audiophile)?
I'm planning to get Sirius soon and would much rather have direct connect instead of FM modulated.
Kenwood KTC-H2EC
Also, for those who have Satellite radio, where did you mount your antenna and how did you run it?
Kenwood KTC-H2EC
mounted my xm antenna on the roof just ahead of the 3rd brake light. Took the antenna wire through the 3rd brake light. If you look at the 3rd brake light, there is a little notch on the front top edge. I put the wire through there, but didn't go under the seal; I wrapped the wirer around the outside of the seal (but still under the lip of the brake light) and didn't go under the seal until the wire was on the bottom of the light in the middle. I figured it'd be less prone to leaking this way. No leaks yet after 6 months or so.
when routing the antenna through the 3rd brake light, is there a connection for the antenna in there or does in need to be routed to the front of the truck and terminate to the tuner? I'm just trying to find out what the best route would be.... and how to get it out of the headliner...
