Underdrive Pulley Set Worth It?
Old Sep 22, 2004 | 12:46 AM
Bullitt4711's Avatar
Read a little on here afterdoing a search, but there isnt much info on these. Are they worth it? Any noticable power?
Also I plan on lifting on 37's somewhere off in the future, and I noticed Troyer said there were some problems with this. Should I wait tell then?
Thanks!
~Colby
Old Sep 22, 2004 | 08:17 AM
dzervit's Avatar
A little search will show almost all the folks that got the pulleys are satisfied and will testify to the reported 14-20HP gain. For just over a hundred bones, I'm planning on it!
Old Sep 22, 2004 | 01:28 PM
jvernacchio's Avatar
How hard is the system to install? I am thinking of going with some pullies and the E-fan kit.
Old Sep 22, 2004 | 01:50 PM
MAD-3R's Avatar
Underdriver Pullies are a good and cheap way to make real power. There are a few things I have learned first hand concerning them.
There are two types. All in one, and "Piggyback" The piggyback type are often a bit cheaper, but require you to place your factory harmonic balancer back on. If you don't you risk serious damage to your engine. The all in one have a weight or "mass" that function as a ballancer.
If you do decide to put them on, I would recommend swapping out your OEM oil pump gear for a billit one. The oem's are pressed metal, and are prone to braking. Billit gears are a bit pricie, $250 - $300, but it adds a lot of piece of mind.
Old Sep 22, 2004 | 02:10 PM
jpdadeo's Avatar
What does the oil pump gear have to do with under drive pulleys?
Old Sep 22, 2004 | 02:32 PM
MAD-3R's Avatar
One of the pulley's is connected to the oil pump. Undue vibration can lead to a failure of the OEM press metal gear. No oil to the crank and pistons, Bad things happen.
Look at about 9 O'clock on the gear.Oil pump Gear
Old Sep 22, 2004 | 04:37 PM
SVTErick's Avatar
i changed my pulley and dont plan on changing to a billet upper pulley or w/e. im not making 500 hp
