Add on Hitches
Old Sep 20, 2004 | 04:04 PM
twilkerson's Avatar
Add on Hitches
Does any one know if Add On Hitches are Bolt on or do you have to drill new holes to mount them. I'm trying to decide if I should just order one online or go have one put on.
Old Sep 20, 2004 | 04:33 PM
inbred's Avatar
99% of hitches these days are vehicle specific and use existing holes. Thing is to make sure you add on extra transmission cooling, temp monitoring, etc. The LEAST important part of a factory towing package is the hitch. Can easily be done yourself, but most likely you're going to want to invite a buddy over for a couple of beers when you decide to install it--trying to hold the hitch in place while you try to get the first bolt through all by yourself is freaking tough--I did it on my last vehicle.
Old Sep 20, 2004 | 04:37 PM
Bluerider's Avatar
2003 and earlier are bolt-on, at least the ones I have had. I can't swear about the 2004, but I suspect they, too, are bolt-on.
https://www.f150online.com/galleries....cfm?gnum=4520
Old Sep 20, 2004 | 04:40 PM
freddytran's Avatar
I went to Discount Hitch. $125 installed. But they did have to drill holes. They said they have had to drill holes on every 2004 F150 new body style they have installed on.
Old Sep 20, 2004 | 04:54 PM
Razor249's Avatar
I had the shop that installed my muffler do the hitch. No markings on it, but it was strictly bolt-on. I watched him do it.
Old Sep 20, 2004 | 11:39 PM
white93's Avatar
A friend and I installed mine, took about 45 min. and it bolted on. I ordered mine from www.hitchmart.com it is Hidden Hitch brand.
Old Sep 21, 2004 | 08:59 AM
BEW119's Avatar
I have a 04 Lariat 5.5 stylside, I bought the draw tite hitch on the internet for about $135. It installed in about 30 minutes with two people. The holes are in the frame, there is no drilling, just bolt on. Most dealers in my area wanted close to $200, installed. so I saved a few dollars. Most hitch websites show the directions in pdf format so you can print them out.
Old Sep 21, 2004 | 02:37 PM
SilverScab's Avatar
Just installed a Hidden Hitch roundtube class III on my '04 Supercab. I bought it from JC Whitney for about $150 delivered. Looks WAY better than the square-tube hitch.
It took three bolts on each side through the existing frame holes. It was about a 30 min. installation. The hardest part was "fishing" the bolts through the boxed frame section, but they provide some steel wires to help you out.
Looky here: www.angelfire.com/space/vache/sign.html
