alternator click
Mine clicks in the morning on start up for about 5 minutes. The air conditioner isn't even running.
WTF? Now you guys are talkin' crazy... changing oil filters, injectors noise... startup clickin'...
Do you guys have your heads on the hood for a bit before you go driving?! The only 'click' you should be hearing is the a/c unit. It's a periodic loud *CLICK* when it cycles. No pattern, not effected by oil, startup temps, etc....
The a/c will cycle in defrost mode for winter time. It's a timed cycle and not constant. This is to keep compressor and clutch free and not locking up. If you click goes away after a short time it may be some thing else;. Injector noise is normal since it's a electric solinode that pulses. If you here a constant cold start tick that goes away have it look at . One member here had a bad tick was his lifter they replaced then ended up with a new engine. Have it looked at . Some of the new engine's have a head problem not confirmed but you never know it's just a mechanical machine that does break. Thats why Ford warranty's them and we buy E.S.P.
