My 2004 Lariat has the captains chairs with the memory seat option (also heated seats). When I press any seat adjustment switch, there is about a 1 second delay before the seat moves. This only happens on the drivers side seat. The passenger seat moves right away when the switch is pressed. Is this normal?
Quote:
Originally posted by Thayer
Mine doesn't do that.
Thanks Thayer. I'll add this to my list of things to have checked when I take it in for the 1st oil change. It seemed kind of odd that it would be designed that way but you never know.Originally posted by Thayer
I know this is a really old thread... But, did anyone find out what the fix was on this? My truck just started doing it too, on the driver's side only. I might add it was fine until the seat cover was replaced at the dealership under warranty... So apparently something was re-installed incorrectly...
Quote:
I have played with the memory seat modules (have a left over memory module and switches from putting power seats in my STX. If there is a detected problem or a code set by a problem in the module, it has some kind of safe mode. Dealer should be able to detect and clear/repair it pretty fast.
Chris
