4x4 isssue?
Old Sep 6, 2004 | 02:13 PM
jansen_l's Avatar
4x4 isssue?
I'm in 4hi making a tight turn in a level grass/hay field. While making this tight turn (wheels won't turn any more) the system kind of binds up and the rear end starts barking because the Limited Slip is kicking in. Anyone else see this? It did it in 4Low as well. My comanche gets the "hop" if you do this but not the limited slip kicking in.
Jansen
Old Sep 6, 2004 | 02:30 PM
dzervit's Avatar
Tight turns in 4 wheel drive on virtually any surface results in some 'binding' and the LS rear end doesn't 'kick in', it works like it's supposed to. Read this if your not sure how rear diffs work... http://auto.howstuffworks.com/differential.htm
