I lost my Daystar instructions - help
Old Sep 3, 2004 | 12:24 PM
Arctic Cat F7's Avatar
Howdy.
I lost the instructions on how to install my day star 2.5 inch coil lift. Can someone email me a copy please. Or post the instructions please. Thanks a million.
My email is jnewell@sueonline.net
Thanks.
Jay
Old Sep 3, 2004 | 01:04 PM
SilvrDrgn's Avatar
How about Emailing Daystar's technical support at tech@daystarweb.com ??
Old Sep 3, 2004 | 04:59 PM
jrich23's Avatar
Check the profile of a member named lanceparkhurst. He has install directions on all of his posts. If you can't find it let me know I have a copy.
Jon
Old Sep 3, 2004 | 05:01 PM
TheBandit's Avatar
Simple . Take tires off . Disconnect upper and lower ball jonts both sides and steering links.. Take out lower strut bolt watching which way it goes . Take the top 3 nuts off of the top of the strut . Remove strut . Compress strut springs . Loosen top nut on strut . Remove strut tower bracket . Remove bushing from bracket . Drive the bolts out of the bracket and put the new ones in . Lube the new bushing and press it n with a bench vise or a press . Reverse all steps . I found it is key to make sure you disconnect all steering linkages and ball joints on both sides makes install easier.I think thats all .
Old Sep 3, 2004 | 05:04 PM
sacteezyjoe's Avatar
Originally posted by TheBandit
Simple . Take tires off . Disconnect upper and lower ball jonts both sides . Take out lower strut bolt watching which way it goes . Take the top 3 nuts off of the top of the strut . Remove strut . Compress strut springs . Loosen top nut on strut . Remove strut tower bracket . Remove bushing from bracket . Drive the bolts out of the bracket and put the new ones in . Lube the new bushing and press it n with a bench vise or a press . Reverse all steps . I found it is key to make sure you disconnect all steering linkages and ball joints on both sides makes install easier.I think thats all .
I also found it easier if you disconnected the front anti sway bar as well.
Old Sep 3, 2004 | 05:09 PM
TheBandit's Avatar
Yeah I was able to get it in with the sway bar in but wrestled somewhat . If you got the disconnect the sway bar to make the job easier .
Old Sep 7, 2004 | 01:12 PM
Thanks for the replys! I will put it on this weekend coming up. I will try to get some pictures and create a gallery.
Thanks.
Jay
