unhappy with radio reception
You can find them by looking at the wireharness on the radio. What I did on my other vehicle was used a wire tester. One that has a pointy end on it and a light bulb or something when you find the wire. What I did was use this tester on each wire, with the car in off position, then turned it to the AUX position. The wire will then be "live" and you can tell which one comes on with the car. OR, I guess you could find some schematics and figure it out that way.
juniorFX4,
Sounds like you know little about electrical systems, or installing a radio. I suggest you find one of your buddies that has installed stereo and have him help you. This is a very easy job. Most of your time will be spent taking the dash apart.
zman
zman
