Made a bad mistake
Old Aug 31, 2004 | 03:24 PM
mikey88's Avatar
Made a bad mistake
After cleaning my 04 FX4 last night I took my kids to school this morning. I noticed after driving about 20 minutes and 65 mph my 4wd switch was in 4L. I must have accidently done that while cleaning it. It stayed in 2wd the whole time and I have not checked to see if the 4wd is working. Is it possible that I messed it up bad. It ran good in 2wd
Old Aug 31, 2004 | 03:36 PM
trierguy's Avatar
I believe 4L will only engage if the truck is running and in neutral not traveling more than 3 MPH. I could be wrong, but if you were driving in 4L you would definitely know it. The truck would run at very high RPM'S and you can only go like 20 MPH.
Old Aug 31, 2004 | 03:49 PM
jpdadeo's Avatar
I agree with tireguy, you can’t go 65mph in 4L. You were still in two-wheel drive.
Old Aug 31, 2004 | 03:51 PM
mikey88's Avatar
Yeah, I know it wasn't if 4L, but the switch was. I just hope it didn't damage anything
Old Aug 31, 2004 | 04:16 PM
JDaddy's Avatar
It did not damage anything. It never ingaged as you know so it was like it never happened.
Old Aug 31, 2004 | 04:40 PM
RMills8's Avatar
Yep, relax and dont worry about it. The truck knew not to switch into 4L and saved you. It is just fine.
Old Aug 31, 2004 | 04:59 PM
rubrnek's Avatar
For the 4L to engage, the truck must be running, in neutral, with the brake fully engaged. No worries...it never engaged.
Old Aug 31, 2004 | 07:03 PM
brchaney's Avatar
in 4-low you can go faster than 20. When I was on the dunes I left my truck in 4-low all the time, I was traveling actually speeds slightly above 20 at times, and going up the hills I had my wheels spinning at like 45-50mph.
Old Sep 1, 2004 | 11:42 AM
wilthis's Avatar
try it
Just try it now and see if it works.
Old Sep 1, 2004 | 12:15 PM
ZMANF150's Avatar
Is the front DS live at all times. Meaning that when the truck moves in 2wd, is the front DS spinning, or is there some disconnect on one of the front axels. I crawled underneath and did not see anything so I am assuming the the front DS spins with the truck in 2WD.
zman
Old Sep 1, 2004 | 04:32 PM
Whew - you had me worried there!
When you said you made a bad mistake, I thought maybe you told your wife that her butt did look big in that outfit!
Old Sep 1, 2004 | 04:36 PM
ford2004F150's Avatar
You can always makeup a bad mistake like that with a Samual Adam's "It's always a good decision"
Old Sep 2, 2004 | 10:20 AM
COFX4's Avatar
I guarantee you would have known it if you had been in 4L....this is a smart truck, dont worry about it, like others have said, there is a procedure you have to go through before it will even go into 4L....
Old Sep 2, 2004 | 10:36 AM
mikey88's Avatar
Well, all you guys were right. It did no damage. I tried it last night and it worked fine. I climbed some hills in 4h and 4L and no issues. I didn't tell the wife she looked big in those pants, but I may have a Samuel Adams anyway!!!!!!!!!!!!!!!!!!!!
Old Sep 3, 2004 | 03:34 AM
ConcreteGuy's Avatar
I did this as well and got a good lesson on how to work the 4x4...I to did no damage...but to my nerves...
I think its a good plan for you to treat yourself with a Samuel Adams ...
