Daystar compression ?
hey ClemsonFx4, i live in clemson and i have the daystar lift on mine if you want to see it email me and i will give you my number so we can link up. i bet you went to clemson 4wheel center they told me the same thing. tsmith2002@aol.com
Actually HHIFX4 I live in Charleston as of now however I'll be in Clemson in the Spring semester. By the way, what year are you? Email me, I'll be at the wakeforest game and would love to see the truck.
Originally posted by robisten8 (snip)
Has anyone with daystars noticed a knocking sound when driving over a bumpy road? Or will this sound go away when they settle in a bit.
i am a junior at clemson, and i will be partying on the lawn in front of the old university ridge during the wake game come by have a beer and check out the truck. ... i just talked to my cousin who lives in chuck town and he said yall are getting some pretty good weather down there!! hope everything is still intact where you are
That's what I figured. Is that what everyone is experiencing as a norm with the daystars?
Originally posted by ford2004F150
jpdadeo,
So no hitting on your kit right? I am almost sold on the auto spring kit. Did you put it on, or have some place install it for you?
Anything you don't like about it...?
Thanks,
-f2f-
jpdadeo,
Thanks,
-f2f-
And definitely nothing is hitting, everything is perfect.
After taking a closer look, I'm pretty sure it's not the control arms hitting the spring. The rubber/plastic that coats the springs has not a scratch and with the metal control arms hitting it, it would most definately have a scratch or some sign of contact.
I just spoke to the guy at autospringcorp.com and he was explaning why some folks are claiming more lift that his kit advertises. The toe-in of the tires is changed when installing the kit, they are not sitting flat so the truck sits higher. The truck must be aligned after installation. Then the truck will ride at the claimed lift height. They only claim being able to clear 33" tires, 35's will fit but will probably rub depending on where your steering lock to lock limiter is set. I'm buying this kit today instead of the daystars just for my own peace of mind. I've heard rave reviews about both kits.
This lock to lock limiter anyone know if it is adjustable . I got the daystar kit in mine and when hitting furthest turning point and slow cornering I get a little squeal noise and the truck feels like she dips down on one side a bit too much . I looked for steering stops on the spindles none to be found . I would like to take a slight bit off my turning radius to see if this corrects the oversteering problem .
