Spongy Rearend
Old Aug 6, 2004 | 12:37 AM
DeVoTee's Avatar
Spongy Rearend
I had the Auto Spring 2 1/2 leveling spacer installed (spacer is 1 7/8 thick/tall) I had the back of the steering knuckle ground slightly, so no clunking or hitting of the spring pack. I plan to add 1" taller block or add a leaf to give a 1/2 rake from back to front.
The problem is that the front end is stiffer (not too stiff) which I happen to love. BUT the rearend feels like it's out of a 1970 something GM wagon.
QUESTION....has anyone added a spring or different shocks to reduce the spongy rear.
Old Aug 6, 2004 | 08:06 AM
carpenter's Avatar
Was it spongy before you installed the Autospring kit?
Old Aug 6, 2004 | 10:37 AM
4Jeeperz's Avatar
I added Rancho RS9000X adjustable rear shocks. After adding a shell, bedslide, and all my carpenter stuff, the rear end felt pretty "spongy". Nice and controlled now. Also adding AirLift airbags this weekend to hold the back end level.
Steve the carpenter
Old Aug 6, 2004 | 10:58 AM
DeVoTee's Avatar
I didn't notice a big difference.... I think the truck had too much of a car like ride. Changing the the front created a noticable diff between the back & front.
Thanks for the info on the shocks....any other suggestions???
Old Aug 8, 2004 | 01:05 PM
DeVoTee's Avatar
BUMP!!!
