Its done 2.5 Daystar with 33's No rubbing
Old Aug 5, 2004 | 12:01 PM
rodnash's Avatar
I just finished it 2004 SCREW with Daystar 2.5, Weld Velocitys 18X8.5 with 6.3" backspacing, Nitto Grapplers 325X60X18 (33's)
Im no expert but I think the back spacing is the key to No Rubbing. That means no cutting or trimming.
https://www.f150online.com/galleries....cfm?gnum=4543
What Cha Think??
I Was torn between 33's and 35's
Old Aug 5, 2004 | 12:05 PM
2000regcab54's Avatar
Linky no worky
Old Aug 5, 2004 | 12:11 PM
OMC's Avatar
OMC
325 = 33's? that seems wrong. I thought 315 = 35's? however I suck at math and I just worked 14 hours so everything seems wrong to me.
Old Aug 5, 2004 | 12:19 PM
roboots21's Avatar
325 or 315 = width of the tire, not the height. these are both around 13" wide, with the 325 being a bit wider than the 315.
Old Aug 5, 2004 | 03:15 PM
rodnash's Avatar
tire size calculator
The miata tire calculator says the 325X60X18 is 33.4"
The Nitto tire site says 32.99"
I would say 33" is accurate
It is a great tool
http://www.miata.net/garage/tirecalc.html
Old Aug 5, 2004 | 05:23 PM
OMC's Avatar
OMC
sorry for my mistake ... like I said it was a long day. where are the pics??? =)
Old Aug 5, 2004 | 05:40 PM
suds5.4's Avatar
You need to fix that link ASAP. That took me to the point where I could edit your gallery, including deleting those albums.
I almost forgot, that looks good!
Old Aug 5, 2004 | 05:45 PM
rodnash's Avatar
Pictures
Thanks for the help guys..............what cha think??
Old Aug 5, 2004 | 06:36 PM
mekinik76's Avatar
your truck looks good, so you would recommend the daystar 2.5" leveling kit, did you put it on yourself? Nice truck!
Old Aug 5, 2004 | 07:19 PM
rodnash's Avatar
I would reccommend the daystar
The Daystar kit works well in getting the front up while leaving you with a stock ride........felt exactly the same, just a bit higher.
I used a local alignment shop that specializes in lifted vehicles.
(250.00 labor charge with alignment) The allignment was out just a bit. You need to compress the springs which can pose a problem for some. I have heard guys on the web site doing it themself. I dont want to get my head knocked off by a spring, so I sent it to the pros. Plus when you have a nice truck I didnt want to chance messing something up.
Hope this helps, RN
Old Aug 5, 2004 | 08:10 PM
nitzer280's Avatar
Yup that setup is flat-out gorgeous!
Old Aug 5, 2004 | 08:33 PM
mekinik76's Avatar
thanks
thanks for the info on the daystar and tires size.
Old Aug 5, 2004 | 08:37 PM
lanceparkhurst's Avatar
Looks great, got the same tires with the daystar on mine also (stock FX4 rims though).
Old Aug 5, 2004 | 09:27 PM
rodnash's Avatar
Hey Lance
Any rubbing...........my buddie has the FX4 and wants to use same tires. He was worried about rubbing with that rim and the 33's
Old Aug 5, 2004 | 11:25 PM
Since I put them on I haven't had much chance to go off road but in day to day driving I haven't had any rubbing yet. I am very happy with them just wish I could have went bigger but not with my garage.
