Help needed; stuck wheel lock
Old Jul 30, 2004 | 05:57 PM
blacklariatfx4's Avatar
Anyone here experience or advise for removing a very stubborn wheel lock?
FYI, I torqued it down to the 150 lb/ft( followed the instructions to use the factory recommended setting for my F150) and now it won't come off. Once I get the damn thing off I'll be thowing them away and switching back to the factory lug nuts.
Old Jul 31, 2004 | 12:39 AM
Grimalkin's Avatar
A liberal dose of good ol' WD40 to flush out the road grime cured my reluctant wheel lock.
Old Jul 31, 2004 | 02:41 AM
Lenticular's Avatar
From: Rio Grande Valley, Tx and the United Kingdom.
Hi
Exactly how is it stuck ?
It won't turn at all or the 'key' for the lug not is not gripping enough ?
One old trick which you probably know is to loosen all the other nuts on that wheel (Don't remove them), raise the vehicle on it's jack, then gently lower to the ground and the force on the one remaining nut will loosen it.
Failing that a substantial chisel held against an appropriate part of the nut, and one well aimed heavy blow from a mallet often does the trick.
Good luck !
Old Jul 31, 2004 | 07:11 AM
Thanks, I didn't know about loosening the other lug nuts. I'll definately give it a shot though.
Old Jul 31, 2004 | 07:44 AM
PC Poppy's Avatar
What we used to do --- and be careful to protect the wheel - is to arc weld a regular nut to it and get a long handle wrench on it. Makes me shudder but it always works.
Old Jul 31, 2004 | 02:28 PM
Thanks for the info. I'm really glad to know that I have some options. I don't have an arc welder but I assume a good tire shop or even the dealer could do the work if the earlier posted remedy doesn't work.
