Front lift alignment question
Old Jul 10, 2004 | 11:10 AM
RED WING NUT's Avatar
For those of you that put on an Autospring, Daystar or any other lift on the front and had an alignment done, did you have to buy any kind of a cam bolts to do the alignment? Is there any adjustment with the stock setup?
Old Jul 10, 2004 | 03:17 PM
dgdee's Avatar
I used the Daystar. The only thing out of spec on mine was the toe. Seems like most people have said the same thing. By angling the tie rod end down makes it get shorter, causing the tires to be pulled inward.
Old Jul 10, 2004 | 03:28 PM
Zoltan's Avatar
I just had my daystar installed two weeks ago. I haven't got it aligned yet. I don't forsee the alignment being to far out of spec, the toe would probably be moreso.
I will let you know.
Old Jul 11, 2004 | 12:54 AM
pa_wolf62's Avatar
You should get it aligned. I installed the 2" spacers and my toe was off by a full 1/4" on both sides.
Old Jul 11, 2004 | 02:30 PM
Dr No's Avatar
RED WING NUT.
The cam bolts are needed only if the camber needs to be reset as ford did not include them with the vehicle.
Mike
Old Jul 11, 2004 | 02:41 PM
Originally posted by Dr No
RED WING NUT.
Mike
Thanks. That's the info I was looking for.
