Am i wrong or right about air conditioning problem
Old Jun 18, 2004 | 04:02 PM
wernst's Avatar
I would appreciate the feedback on this one guys.. I have been having trouble with my air in my new 2004 F150. When i select Max/AC it only stays on for 15 minutes. A friend of mine has the exact same truck and his stays on until the truck is turned off. Anyway, I took it to the dealership and they tell me that this is designed this way to keep the AC from burning up. I call BS on this. Does anyone know if it is or isn't suppose to go off after 15 minutes. If it is I want mine broken like my friends.
Old Jun 18, 2004 | 04:12 PM
jpdadeo's Avatar
Mine stays on until I turn it off. If I shut the truck off, it will reset and have to be turned back on. I've never heard of the A/C burning up because it’s set on Max A/C to long. It sounds like your service department is pulling your leg.
Old Jun 18, 2004 | 04:15 PM
Mike99a's Avatar
The A/C in my runs for as long as I have the button is set to on. I don't have any auto climate controls system in my truck and that is what is probably shutting yours down? Sounds like a programming problem with the A/C system electronics, a compressor will not burn up from extended use if it has proper voltage to it and proper plumbing done.
Old Jun 18, 2004 | 04:17 PM
wernst's Avatar
Thanks for the quick responses. I didn't think that sounded right. I called the ford hotline and they weren't much help either.
Old Jun 18, 2004 | 04:38 PM
TUFF FORD's Avatar
There was a decent post on this sometime back, and I think the best answer they could come up with was that after a period of time, the recirculating system kicks off to bring in fresh air.
Old Jun 18, 2004 | 04:40 PM
momalle1's Avatar
Wernst, if you have EATC, which I can only assume you do. the owners manual states that it will turn of the recirc by itself.
Recirculation control: Press to activate/deactivate air
recirculation in the cabin. Recirculated air may reduce the amount of
time to cool down the interior of the vehicle and may also help reduce
undesired odors from reaching the interior of the vehicle. Recirculation
can be engaged manually in any other airflow selection except Defrost.
Recirculation may turn off automatically in all airflow selections.
Old Jun 18, 2004 | 05:05 PM
wernst's Avatar
yeah.. i saw that but I'm confused about what is correct now. A bunch of people here, including my friend's F150 2004 doesn't switch itself off. so?
Old Jun 18, 2004 | 05:47 PM
ieee_raider's Avatar
Mine doesn't, but I have manual controls.
Old Jun 18, 2004 | 07:58 PM
momalle1's Avatar
I've heard rumors that there is a flash available to change the behavior.
Old Jun 18, 2004 | 08:08 PM
jpdadeo's Avatar
wernst, do you have EATC or not?
Old Jun 18, 2004 | 08:12 PM
dzervit's Avatar
I'm guessing he doesn't have ETAC.. .I have a lariat and no Max A/C button.. do they make different ETAC systems?
Old Jun 18, 2004 | 08:21 PM
jpdadeo's Avatar
The lariat doesn’t have a Max A/C button but it does have the recirculation control button. When I use my R/C button it has never turned off by itself, I always disengage it because it’s getting to cold in the cab.
Old Jun 18, 2004 | 08:40 PM
dzervit's Avatar
Exactly... the guy said he had an issue with his Max A/C shutting off, not his recirc... then momalle1 said that he assumes the guy has ETAC.. but I don't think he does... does that make sense? At any rate... the guy needs to take the truck to his dealer...again.
Old Jun 21, 2004 | 01:54 AM
wernst's Avatar
Yeah sorry about that.. When I said Max AC I was meaning recycled air button. I have a Lariat with the electronic controls. I still see no reason why Ford would have designed this to go off after 15 minutes. Like I mentioned before, my friend with the exact truck doesn't have this problem.
Old Jun 21, 2004 | 07:16 AM
Clem's Avatar
The EATC in my Lariat will stay in recirc. indefinitely, but only when the A/C is engaged. Without the A/C on, it turns itself off after 60 seconds. I took it in back in December complaining of this and they replaced the "EATC Module", which is the whole head unit with the display and buttons. The new one does the same thing as the old one which leads me to believe that the PCM is to blame for this. However, I had a reflash during the same visit and - no difference. So, I gave up and I just live with it.
