Removing 2" Spacers from rear end...
Old Jun 4, 2004 | 03:39 PM
fatboy0103@cox.'s Avatar
Can we simply remove the 2" blocks from the rear end?
Do I need to get differnt "U" bolts/spacers..etc...?
Will I need some sort of thin rubber bushing in place of
the 2" blocks?
Has anyone done it?
I can't take it anymore, it needs to be LEVEL!!!
Thanks!
Old Jun 4, 2004 | 03:56 PM
TUFF FORD's Avatar
I could have SWORN atleast one person has done this....let me do a little digging...
Old Jun 4, 2004 | 04:07 PM
TUFF FORD's Avatar
start here
a little info
rear end drop
Old Jun 4, 2004 | 05:13 PM
hihosilver's Avatar
Thankfully this is a simple job. Order Ford #4L3Z-5705FA U-bolts to replace the existing parts. Remove the spacers and U-bolts and reassemble with the new U-bolts. I torqued the nuts down to 80 ft-lbs on the new U-bolts.
I also recommend spacing the front edge of the seats up to prevent that "falling forward" feeling in the 40-20-40 seats in my FX4. Remove the capscrews with a T-50 Torx socket and pry the front edge of the seat up enough to slip in 3/4" nuts as spacers.
Reinstall the original bolts and presto the vehicle feels much more civilized!
I had to do this almost immediately after receiving my truck for comfort. I have over 10,000 miles on my truck and am very happy with it!
Old Jun 4, 2004 | 05:48 PM
AHHHH..... You guys are absolutely awesome!!!!
Thanks!!!
Ed
Old Jun 4, 2004 | 08:04 PM
Originally posted by TUFF FORD
start here
a little info
rear end drop
I don't understand why everyone in the links you posted are talking about "shackles and springs" costing much $$$$ when all you have to do is pull the 2" blocks out and put new "U" Bolts in...???
Can anyone offer any insight? Is there a ride performance loss with simply removing the 2" blocks??? If not, why are folks spending so much money to lower the rear end....???
