Aftermarket Head Unit to Audiophile System
Old May 24, 2004 | 11:40 PM
techsn's Avatar
Has anyone seen a plug-and-play connectort for installing aftermarket head units in the '04 with Audiophile? I know companies like Metra and Pac Audio make tons of those kinds of things but I have had no luck finding anything...any help greatly appreciated.
In case it matters:
I want to install the Kenwood DDX7015 double din HU - will also need mounting kit but I'm assuming it comes with unit.
Old May 25, 2004 | 05:23 AM
grayflare's Avatar
I dont have the audiophile, but Scosche made the wiring adapter that I used in my truck. You can get it from Crutchfield. Also you will need a double- din installation kit for the head unit. You can get a Metra kit from Crutchfield or Circuit City. This is the one I used.
Old May 25, 2004 | 09:07 AM
Sticker Steve's Avatar
The Metra adapter number is 70-5520
These guy's have them but they are $17.50. I'm sure they can be had for less. This is the harness that plugs into the truck for the large plug.
The problem your going to run into is getting an adapter for the sub plug. It is one of the smaler plugs that runs to your audiophile sub. Check metras website for a phone number and call them. They may have something for this by now. If you want it done now you may have to splice into this connection. These are actauly low level inputs on this amp and all that's missing is the rca connector. This plug also covers the amp turn on lead.
I had checked with Schosche in January and at that time they had nothing for the truck side of the 04 150 and told me it would be a while.
