billet grille FX4
Old May 22, 2004 | 01:51 PM
g2oofy82's Avatar
billet grille FX4
Has anyone installed a billet grille in an FX4. I am thinking of a black grille from carriage works.. What i need to know is do you have to cut anypart of the grille. It looks like the gray part comes off with a couple of screwws. Can anyone help?
Old May 22, 2004 | 02:51 PM
Sticker Steve's Avatar
I have the replacement CW billet. No cutting but you will have to drill 4 holes. Pretty easy install. The grey comes off the outer ring with compression clip deals. You peel the tape and release the clips. It's the hardest part but not complicated.
Old May 22, 2004 | 03:04 PM
g2oofy82's Avatar
billet grille
Thanks. Where do you have to drill holes. if for some reason i wanted to put original grill in will the holes be visible.
Old May 22, 2004 | 03:07 PM
Not visible, they go across the bottom of the surround between the grill and the bumper. It's a good fitting grill.
Old May 22, 2004 | 03:23 PM
lanceparkhurst's Avatar
I have the black CW replacement on my FX4 also. The holes that have to be drilled are in no way visible with the hood shut so no one would ever see them. And I'll second that it is a good fitting grill, and I think it looks great.
Old May 22, 2004 | 09:59 PM
smcFx4's Avatar
Yes'' I got the bolt over and i had no holes to drill..
Check It Out"
See all photos
https://www.f150online.com/galleries....cfm?gnum=3517
Old May 22, 2004 | 10:07 PM
Zex's Avatar
Zex
I also have the replacement grill from CW. Dont know if i would go black though, it would look like a huge hole in your front end.
Pics here
http://homepage.mac.com/zexz/PhotoAlbum10.html
Old May 22, 2004 | 11:32 PM
tpeterson's Avatar
Here's my setup
Old May 23, 2004 | 04:21 PM
Zex's Avatar
Zex
tpeterson, get the lower one also. they look great together.
Old May 25, 2004 | 07:07 PM
hellbound F-150's Avatar
Are there any billet grills that replace the 6 piece system and just use one whole piece?
I have the same grill, but I want the one piece billet.
Old May 25, 2004 | 07:11 PM
That's what mine does. You want the one piece billet replacement
Old May 27, 2004 | 01:37 PM
Good deal thanks. I got the part #'s.
Old May 27, 2004 | 03:07 PM
purty_2004's Avatar
tpeterson!!!!
Originally posted by tpeterson
Here's my setup
Where did you get that Grille??? That's what I've been looking for and cannot find one... or maybe I've found it and just don't know it. Every thing I've found either goes over the original grille or just looks cheap, but I like yours!
Old May 27, 2004 | 05:02 PM
tpeterson's Avatar
purity I got it from TAG Motorsports - I can't remember the name of the grill though sorry! TAG Motorsports is in Escondido, CA dail information to get the #. I know that doesn't help much but i don't have their # handy.
Tim
Old May 27, 2004 | 05:04 PM
purty_2004's Avatar
Thanks for the info
