Blaupunkt in 04 front doors
What might sound good to you might not sound so well for the next guy. Has alot to do with personal preferance and taste in music and how you like to hear it. Make sure to listen to them with as close of a match of your actual intentions. Use the same power and even take in a CD of yours to listen to them.
What model were they and what did they want for them? What other mods are you doing on the sound system??? I can't get you a personal experiance but could help you look through the numbers to see if they are a good match for how you plan to use them and if they are a good deal.
GreyScab
I have a 2004 Screw, this is what I did.
Kept the 4 factory speakers, for now since there new and really don’t sound that bad, and added a pair of JL AUDIO VR075-CT tweeters in the front doors. Put a Subwoofer in a custom built box under the rear passenger seat with a JL AUDIO 8” Poly-Subwoofer. Under the passenger front seat there is an ALPINE MRP-T220 Bass Engine. It sounds pretty good and I’ll get some use out of my factory speakers too.
I wanted to keep the stock Single CD head unit provided someone finds a way to use the AUX at some point. I have a RF punch 120 amp and 10 inch Sub I pulled out of my 01 F150... that sounded pretty good in it. I just need a box for under the back seat in the new truck. The stock speakers just seem a little distorted at higher volume so I thought of changing out the fronts...maybe to the Blaupaunkt comps for now and maybe add an amp to them later. The rear door are just for fill anyway so I wasen't to concered about them. Thoughts?
GreyScab
This is the sub box and the sub amp I have. Check um out
https://www.f150online.com/galleries/images/4205-6136-92286.jpg https://www.f150online.com/galleries/images/4205-6136-92285.jpg
