FRONT splash guards
Just washed my truck, with 8,500 miles on it, and found annoying dings in the passenger side door from the front tire throwing stuff up onto it. I have seen discussions here of how to place rear splash guards on the front, but they require mods to the step boards. Anyone found front splash guards that require no mods to the truck?
Thanks, Brad |
There are Ford made molded plastic splash guards for all 4 wheels. I just ordered some off ebay for $10 plus $10 S&H.
If you have the black platform running boards, the Ford splash guards (according to several individuals) didn't fit unless you cut the tip of the board off. If you purchase the splash guards made by Husky, they fit just fine with no running board modification necessary.
If you have the tube type running boards, the Ford guards should fit just fine. |
Originally posted by Neil If you have the black platform running boards, the Ford splash guards (according to several individuals) didn't fit unless you cut the tip of the board off. If you purchase the splash guards made by Husky, they fit just fine with no running board modification necessary. If you have the tube type running boards, the Ford guards should fit just fine. |
