TSB's
Old Apr 19, 2004 | 08:58 AM
04fx4Scab's Avatar
TSB's
I think some of these apply to our trucks.
The Following 13 Technical Service Bulletins May Apply To Your
2004 FORD F150
00000 POWER TRAIN
Bulletin No: 17305
Date of Bulletin: 01/21/2004
Summary Description:
SOME VEHICLES BUILT BEFORE 9/16/03 EQUIPPED WITH A 4.6L/5.4L ENGINE AND 4R75E TRANSMISSION MAY EXHIBIT THE TRANSMISSION CONCERN INDICATOR LAMP (TCIL) ON WITH DIAGNOSTIC TROUBLE CODE P0733 (3RD GEAR RATIO ERROR) AND/OR P0734 (4TH GEAR RATIO
10000 ELECTRICAL SYSTEM
Bulletin No: 17308
MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0606 WITH/WITHOUT OTHER DTCS. *TT
62000 STRUCTURE:BODY
Bulletin No: 17309
WHISTLING NOISE FROM FRONT OF VEHICLE ABOVE 50 MPH. *TT
53600 EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Bulletin No: 17261
Date of Bulletin: 01/20/2004
INACCURATE AMBIENT TEMPERATURE READING AND/OR POOR AIR CONDITIONING PERFORMANCE. *TT
Bulletin No: 17262
CHARGING SYSTEM WARNING INDICATOR ON WITH POSSIBLE DIAGNOSTIC TROUBLE CODE P0622. *TT
46400 SERVICE BRAKES, AIR:ANTILOCK:ABS WARNING LIGHT
Bulletin No: 17272
LACK OF POWER WITH THE MALFUNCTION INDICATOR LAMP (MIL) ON AND DIAGNOSTIC TROUBLE CODE (DTC) P2106 (THROTTLE ACTUATOR CONTROL SYSTEM - FORCED LIMITED POWER) STORED AND ANTI-LOCK BRAKE SYSTEM LIGHTS ON. *TT
Bulletin No: 17294
CHARGING SYSTEM WARNING INDICATOR ON FOLLOWING ALTERNATOR REPLACEMENT. *TT
62300 STRUCTURE:BODYOOR
Bulletin No: 03204
Date of Bulletin: 01/14/2004
UNABLE TO OPEN THE DOOR WITH THE INSIDE DOOR HANDLE CONDITION, ALTHOUGH THE EXTERIOR HANDLE WORKS PROPERLY. *TT
10000 STEERING
Bulletin No: 03208
STEERING WHEEL SHIMMY/NIBBLE AT 100 KM/H (60 MPH) AND GREATER SPEEDS ON VEHICLES BUILT PRIOR TO 8/20/2003. *TT
Bulletin No: 17233
Date of Bulletin: 11/18/2003
CHARGING SYSTEM WARNING INDICATOR ON INTERMITTENTLY ON VEHICLES BUILT BEFORE 9/30/2003. *TT
Bulletin No: 17238
MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P1233, WITH OR WITHOUT ANY DRIVEABILITY CONCERNS. *TT
Bulletin No: 17161
Date of Bulletin: 11/17/2003
INSIDE DOOR HANDLE INOPERATIVE. *TT
10000 STEERING
Bulletin No: 17169
STEERING WHEEL NIBBLE AT 60 MPH AND HIGHER. *TT
