Seeking picture of different tire sizes
Old Apr 4, 2004 | 10:05 PM
Dusty1's Avatar
Lightbulb Seeking picture of different tire sizes
I'm looking for a web site that shows a picture of different size tires next to each other for a proper comparison.
I wonder if it's worth it to swap out my P275-65-R18's with P285-60-R18's. I do not intend to put in a lift or leveling kit. It would really be nice to see them side by side to see if it's worth the $.
Old Apr 4, 2004 | 10:35 PM
Grimalkin's Avatar
Dusty...you didn't indicate whether your objective is a WIDER tire or a TALLER tire. In the example you gave, the 285 will be 10mm wider (slighter wider than a 9mm/.38 bullet), but 7.75mm LESS TALL than the 275/65. If y'all go to any tire manufacturer's web-site, you can find the tire dimension info you're looking for.
Without doing that, you can crunch the numbers yourself if you understand what tire size numbers mean/translate to and their relationships. For example (keeping it simple), 285 is the distance in mm through the sidewalls (width of the tire), 60 is a % figure that translates to sidewall height, in this case 60% of the 285 (the sidewall heigth) is .60 X 285=171mm. Convert mm to inches, multiply by 2 (there are 2 sidewalls, top and bottom), add the tire diameter (18 inches or whatever) and you arrive at total tire height) plus or minus depending on tread thickness, etc.
Old Apr 5, 2004 | 06:08 AM
Dusty1's Avatar
Grimalkin,
Thanks for pointing out my error. I am looking for the tallest and widest tire that can be installed without the need for a lift kit. That's the bottom line. That second number always screws me up, as it's a ratio of height to width.
Before I spend the money, I just want to see a picture of what I have now and the new tire next to each other so I can see if it's really worth spending so much money.
Thanks for your input!
