Job 1 vs. Job 2
Old Mar 27, 2004 | 09:02 AM
fyrfytrjeff's Avatar
Job 1 vs. Job 2
I've been reading threads that refer to Job 2 vehicles, and I assume it's meant to be a second run of trucks that would have all of the current updates and modifications in the build. My question is how I find out if I have a Job 1 or a Job 2 vehicle. Is it on the window sticker or on the door plate anywhere, or does it go by the build date of the truck?
Thanks for your replies...
Jeff
Old Mar 27, 2004 | 09:22 AM
Zach's Avatar
It's my understanding, that the first half of the production run is Job 1. After the first of the calendar year, when production resumes, Job 2 begins. Someone please correct me if this is not the case.
Old Mar 27, 2004 | 11:54 AM
vtn98's Avatar
It's not the second half of the calendar year, but the second half of the production year. You should be able to do a search for it, but I think Job 2 trucks were built starting in February. I know mine is a Job 2 because I ordered mine and it says "JOB #2" on the order sheet.
Old Mar 27, 2004 | 02:38 PM
openroad's Avatar
Check the window sticker of the truck. If it is a job 2 truck it will say so. Mine was built 01-05-04 and it is a job 2 truck.
As for the updates I'm not sure. All I know is that I'm happy with my truck and the only problem I have had was a noisy belt that some belt dressing fixed. Hope that helps.
Old Mar 27, 2004 | 04:13 PM
ultramaxer21's Avatar
I've got a job#2 truck and IMO the much talked about "throtle lag" due to drive by wire seems to be MUCH better. I test drove 3 Job#1 trucks and did notice the throttle lag. However this is just my opinion. Also do date with 200 miles I've not experianced any vibrations on my truck other than what I consider normal due to various road surfaces.
Old Mar 27, 2004 | 09:38 PM
Well, my truck was delivered the beginning of March, so I would assume it is a Job #2 vehicle. Sorry to say, though, that I am experiencing the Rear End Shudder, Brake Squeal, and Rear Door Lock problems that have been the topics of discussion in this forum. I drive quite a bit for work, and I have 2500 miles on it already, so I'm due for the first oil change in about a week or so. I'll have the dealer look at these items then and hope for the best.
Thanks much for all of the replies.
