Finished install. Give comments.
Check out the pictures in my gallery below. Very please with the sound and output. Done for under $500 not including my labor!
Originally posted by blitzkrieg
Nice work. You do it all yourself?
Originally posted by Night Owl 2
Dupuis, very nicely done. What size dimension on your box ?
Will
Will
Originally posted by momalle1
What are using for a head unit? Is this connected to the factory unit?
I did not want to mess up the look of my console.
Looks good,
I think that 8's are awsome....tight and punchy, not boomy and muddy sounding. Do you have .50 for each sub or for both? It's nice to see that the systems are finally begining to take shape in the 04's around the country.
Originally posted by jimbo5o
Looks good,
Looks good,
This is in a 2004 F-150 Lariat Super Crew. I did not want to mess up the look of the front console so I kept my stock 6 disc HU in place and used high to low line convertors. Surprisingly it ended up sounding very good. All I need.
Not much room under rear seat to work with. 6'' at the deepest point. I ended up with .50 cubs tuned to 35 Hz after all displacments. The port ended up being 3'' thin wall PVC aprox. 25.5'' long with one 90 de. turn in it. Not what is rec. for 2 RE8s, but thats all I could get in between the seat brackets. This started out as me just wanting to gain alittle bass. Well I got it and more.
These 8s are unbelieveable. Having competed in the mid 80s with 2 12s, I was blow away at what these little things put out. Because my box was so small for 2 RE8s ported, and not knowing how it would sound, I built 2 boxes, the other was .45 sealed. I tried that one first. Sounded good and I was very pleased, but when I put the subs in my ported box the out put gained was well jaw dropping. This in a .50 proted box how can it be. I was told here and by David at RE that it would be very hard to stop port noise and that my port would be to long for the size box that space would allow. I thought I would just give it a shot and WOW, WOW I sure am glad I did.
Bass is very tight and reaches very low. I hear notes that my 15'' home sub hits. All this with 2 RE8s. Needless to say, I am very happy with my install and would tell any one looking for bass with little areas to deal with to go with these little monsters.
The only other thing I am planning on doing is to upgrade my cheap 4 channel amp to an Avonixx 440.4 to match my other amp. I will stack both where my Avionixx is now.
Sorry so long. Just very pleased with the sound I ended up with.
Originally posted by cdemot02
What did you have to do to get the 6.5s to fit in the front door?
