Aftermarket Subs
Right next to the gas peddle there should be a rubber plug that goes straight into the engine compartment. I just drilled a small hole in the middle of that, and pushed the power wire right in. Used a couple of zip ties to keep it away from hot things and ran it right under the carpet on the inside.
Pretty easy.
Hope this helpled.
Pretty easy.
Hope this helpled.
