Nanners, Smokers and Jokers...???
when you write a post look to the left .. right under "your reply" it should say smilies with 27 little pics under it. just put the curser where you want the face and double click the one you want it should show up on your post
Message Icon
Your Reply:
See Forum Rules (below) for
more information about what
codes you are allowed to use
in your posts.
Options:
Attach File:
This is what shows up. The only little faces I see are the ones ABOVE in the Message Icon. There are only 14 of them.
Your Reply:
in your posts.
Options:
Attach File:
Forum Rules:
You may post new threads
You may post replies
You may post attachments
You may edit your posts HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
I clicked on the "smiles" in "Smiles are ON" and they showed me all of the icons and there meanings. Do I have to type in the words every time? ie.,
ie.:"banana"::"banana"::"banana": (understand that i know the quotes don't belong but that is the only way I can explain. I have to type in the words everytime. I don't see the icons though.
vB code is ON
Smilies are ON
[IMG] code is ON
These are the ones you should be able to see.
https://www.f150online.com/forums/mi...on=showsmilies
They are not laid out like this, it's just the icons themselves.
You may want to post a new thread here:
https://www.f150online.com/forums/fo...?s=&forumid=31
Someone with more computer skills than me may be able to help out.
Forum Rules:
vB code is ON
Smilies are ON
[IMG] code is ON
I will give that a shot Tuff Ford
vB code is ON
Smilies are ON
[IMG] code is ON
You can 'manually' type it in, but you should be able to click on it once and it will post it in your thread. If I double click on it, it posts it twice. I found out last night that there is a maximum about of 'smiles' you can put into a thread before it cuts you off. I don't know what that magic number is. It's more than three!
I hope you get it worked out.
