vibration in doors from sound
Old Feb 27, 2004 | 08:37 AM
mxz600's Avatar
The rear passenger door on my Scab is vibrating with bass when i turn up my stereo. I got a 6disc no audiophile system. Its driving me nuts to the point i got my sound system signals moved to just the front. How can i deaden the vibration!!!!!!!!!!!!!
Old Feb 27, 2004 | 09:09 AM
Sticker Steve's Avatar
You need to open the panel up and see what's going on. It sounds like either the speaker is loose or blown.
I have hardly any vibration even with 2 10's and 1500 watts. Something is wrong.
Old Feb 27, 2004 | 10:41 AM
mxz600's Avatar
true dat, even though its impossible to get 10's in the rear doors. I will look at it. Maybe i need some sound dampening material to put into the door panel.
Old Feb 27, 2004 | 10:46 AM
chemgod's Avatar
It's my understanding that in some of the 2004's the new sound insulation has been coming loose inside the door panels. This has been described as the same noise you are hearing. I believe it is a waranty issue and the dealer should be able to look at it. Just a thought.
Old Feb 27, 2004 | 12:06 PM
I didn't mean the 10's are in the doors, just that my interior is getting pounded by 10's and I have no Rattles.
Sounds like Chemgod might have your answer. What ever it is should be covered under warranty by your dealer. There shouldn't be any vibrations coming off your panels caused by the speakers, especialy stock.
Old Feb 27, 2004 | 01:43 PM
pa_wolf62's Avatar
Re: vibration in doors from sound
I had the same problem. Took it to the dealer and they opened up the door panel and found a big chunk of plastic.
Old Feb 27, 2004 | 02:20 PM
jdpete's Avatar
its not so much of a vibration with mine, but it seems to get painfully distorted when up loud----kind of like a vibration, but just not clear---I put the bass about half and the treble a little higher---I have never really like a lot of bass (I listen to mostly country or alternative) I also turn on compression---does anybody else feel this way about their audiophile? Just seems it has no clarity when turned up above half way----thanks for any suggestions-----
Old Feb 27, 2004 | 08:12 PM
mxz600's Avatar
well i took off the front driver door screen to see just what is behind it. Even though its the rear doors that vibrate under load basey songs. Well i broke at least 4 clips taking it off tried to fix it with glue, didn't work and put it back on and now it doesn't fit in tight, it is kinda loose
Old Feb 28, 2004 | 11:28 AM
chemgod's Avatar
That's why we tried to say it is waranty work and the dealer should be able to do it at no cost. Sorry.
Old Feb 9, 2005 | 07:26 PM
aggie '01 F-150's Avatar
first i know this is really old - but this is all i could find when i searched
okay
i read this email and I've got a few questions.
I have the same shudder/rattle whatever you want to call it, only mine is in the front drivers side door.
figured it was a blown speaker and wanted to replace all speakers anyway, so i bought some infinity kappas and now it is worse because of the stronger base in the new speakers
i can stop the shudder by pressing on the door panel, so i am assuming the panel is loose somehow. this is an 04 supercrew with the non-audiophile system.
has anyone else had this problem. I've taken both the drivers and passenger door off to try to see if anything looked unusual, but i didn't notice anything.
any help would be appreciated it.
