WARNING: Jack removal.
Old Feb 26, 2004 | 04:38 PM
Grimalkin's Avatar
I recall a post last fall that warned of the difficulty in removing the jack, especially for the first time, in the dark, with no familiarity of how it is secured in the bracket.
I removed my jack today from under the seat and relocated it to the bed under a locked tonneau, along with my emergency kit, tools, etc. Be WARNED: unless you have made a dry run on removing the jack, I can absolutely assure you that you will find it not difficult, but impossible to remove when you need to do so later. I could not remove the jack until I removed the entire assembly, including the bracket, from the truck (11MM bolts) and pried the jack out of the bracket with a crowbar (a heavy screwdriver will likely work also).
If you have road emergency service, relax...if you don't, you had better get some practice with this device of the devil or you'll kick yourself later.
Old Feb 26, 2004 | 04:57 PM
Dupuis's Avatar
What are you talking about. It's removes very easy by removing the big T bolt that holds it to it's bracket. It is hand tight. You do know about that bolt don't you?
One more thing. Once you remove that bolt you may have to hand turn the jack to make it shorter to remove it from the bracket.
If you want a better place for you jack, look in my Gallery.
Old Feb 26, 2004 | 05:09 PM
Arctic Cat F7's Avatar
I bought a bottle jack from wal-mart it comes in a case makes for easy storage. Plus I always keep a 2x6 about half a foot long to put the jack on when lefting the truck up. I had to change a tire on my 97 Flareside 4X4 and the jack would not lift the truck up and it keep sinking into the gound. The 2X6 makes for a great plat form to put the jack on.
Old Feb 26, 2004 | 05:25 PM
TUFF FORD's Avatar
JACK AT WALLY WORLD?!?!?! That's it, I am moving to Ontario.
Old Feb 26, 2004 | 07:13 PM
TeckBargins's Avatar
Re: WARNING: Jack removal.
Hahah that what AAA is for!
Old Feb 27, 2004 | 09:21 AM
We have a great store here in Canada called Canadian Tire this place is heaven for automotive stuff. If you can't find it there then it does not exist.
Old Feb 27, 2004 | 09:23 AM
bwhitt's Avatar
I'm gonna agree with this one. The problem that I had was that since both the jack and the bracket are black metal, I couldn't tell there was even a bracket there.
Old Feb 27, 2004 | 09:38 AM
J-150's Avatar
Newfie Speed and Sport!
The ultimate hangout on a Saturday afternoon!
Notice that some locations have a Tim Horton's kiosk? What a Canadian thing, hanging out at Cdn Tire with a Large Double Double.
Old Feb 27, 2004 | 10:19 AM
Wstand's Avatar
I guess yall are lucky, My 2004 didnt come with a jack at all!
they left it out
HELP I HAVE A FLAT!!!
Old Feb 27, 2004 | 10:26 AM
Loans4u's Avatar
A bottle of Jack from Walmart? I didn't even know they sold hard liquor at Walmart. I don't think it is a good idea to keep an open bottle of Jack in your truck. Second of all, don't these new trucks all come with road side assistance?
Old Feb 27, 2004 | 10:27 AM
Wstand's Avatar
Wal-marts sell liquor! what country do you live in? In Texas they dont, In Louisiana they do!
Old Feb 27, 2004 | 10:55 AM
JohnAndDar's Avatar
Wow, what a transition this thread took. It went from "bottle jack" to a discussion about a "bottle of Jack"...
Old Feb 27, 2004 | 11:05 AM
chemgod's Avatar
They sell liquor in Wisconsin, but then again everyplave in WI does.
Old Feb 27, 2004 | 11:36 AM
BrewMaster's Avatar
I'll keep bottle of Jack under the back seat behind the jack. In case of emergency I can drink the Jack while AAA takes care of the problem.
Old Feb 27, 2004 | 12:17 PM
Lenticular's Avatar
From: Rio Grande Valley, Tx and the United Kingdom.
That original post was mine......
All I did was to gently SUGGEST that it wouldn't be a bad idea to have a practice sometime before the emergency happened on a dark, wet, winter's night.
The response was remarkable...from being just plain dismissive to really quite rude.
I have owned enough vehicles in my life to know that a few moments spent one pleasant weekend afternoon in the comfort of your own drive or garage will pay dividends when you are unexpectedly caught out in circumstances as described above.
I stand by my original statement that I think the whole setup is poor.
Anyway TRUBLUSCRU....softlee softlee catchee monkee !!!
See what I mean.
No...probably not.
