1/2 Daystar installed
I used the top spacers and new studs and got just the right amount of lift I was looking for
https://www.f150online.com/galleries....cfm?gnum=3790
Its the 2 spacers that have the 3 slots in them that go on top, as far as getting the spring compressed back I had no trouble, used a coil compressor at the ford dealership. As long as you can use a decent compressor you will be fine.
MX81
What kind of spring compressor did you use? I can't find a compressor that will fit 3/4" wire diameter springs. I plan on doing the top half this weekend. Your truck looked just right!
Any chance of some closer/brighter photos?
That does look good, but just the one pic doesn't quite give me enough of an idea of what it really looks like.
Are those 17" or 18" wheels?
Thanks...
Thanks...
MX81
Yea I was typing my reply while you answered. I will probably take my strut assembly someplace and have them compress it and take the top plate off so I can install the longer bolts. 1.5" looks about right and won't compress the cv boots so bad.
Its the bolts that holds the lower A-frames, there the exact same but have the eccentrics on it, I believe since 97 you have to purchase these to get it aligned, could be wrong though.
