Vibration Sound Fixed
as400pro
quote:
I hear a vibration/humming sound coming from the steering wheel cowl or in that vicinity, maybe behind or below the dash.e: as400pro
Re: as400pro
quote:
Originally posted by tcf
In an earlier thread I stated I had a similar sound. I stopped Sat. and had my service advisor listen to it. He heard it also. I'm making an appointment today to have it looked at this Thurs. I'll let you know what they find.
The dealer located the noise. It was the air intake assembly. The nozzle end which attaches to the fender well has an o-ring which dampens the vibration from the nozzle. Mine was missing so they replaced it. No more vibration. This might be the problem you and TUFF FORD are experiencing. BTW mine has the 5.4L. Good luck to you.
Re: as400pro
Thank you TCF for posting the information.
I will print it out and take it to the dealer with me.
I may stop by there tomorrow without an appointment just to let them hear the vibration sound.
After listening to it a few more times since my original post I do believe that something behind the firewall is the initial cause and is causing the virbration to affect the area below/behind the dash in the steering column vicinity. Since the sound is only heard once per trip it has made it more difficult to trace.
Re: Vibration Sound Fixed
If the vibration doesn't come back I will wait until my first scheduled service and mention it to the service advisor and show him how the o-ring doesn't fit well and let them correct it at that time.
Thank you tcf!
I can't wait to get down to my truck to find out if this fixes it. I have been listening and thought it was coming from behind the steering column or in the dash. This has GOT to be it!
I'll let yall know.
I'll let yall know.
TUFF FORD & as400pro
I was just wondering how you made out with the vibration noise. Since the dealer fixed mine I haven't heard any noises.
I am assuming the loose air intake tube was causing it.
Thank you for the information that led me to discover the cause of the vibration.
If it does come back I will re-post.
