04 Supercrew 2WD
2x4 SCrew
I am in central IL. There plenty of 4x4 from which to choose, but I had the dealer search for a 2x4, enough were found that I had a decent selection. Most dealers trade back and forth. You can do the search yourself just go to the FoMoCo website.
USAhttp://www.ford.com/en/default.htm
Canadahttp://www.ford.ca/
2x4's can be found at any lumber yard in the country. However, if you're looking for a 2WD truck, I would recommend a 4x2.
I have a 4x2 Lariat and absolutely love it !! The ride is second to none, barred none. I have 3.73 LS and am getting around 14.3-15.5 MPG, depending on driving.
I picked up my True Blue Screw 2wd on Wednsday and love it. I haven't made it through the first tank of gas yet, but it should be around 16-17 with the 3.55's. I'll post back after we run a couple of tanks through it.
I've had my 4x2 Supercrew since early Sept.. It's ride and handling are 1st rate. I look forward to driving it. With the 3.55 ratio, I get about 15mpg.. Maybe I'm crazy, but power seems to get better and it has a throatier exhaust note with time.
