Auto Transmission no service
Old Dec 31, 2003 | 05:56 PM
winters's Avatar
Whats up with the transmission not being serviceable.
I am not a very big fan on things that you are not to service.
I guess I am still thinking of things like lubed for life balljoints&tie rod ends all you do is replace them.
What do you think?
Old Dec 31, 2003 | 07:32 PM
bikelover's Avatar
Where did you find this out?
My maintenance schedule appears to call for fluid changes.
Old Dec 31, 2003 | 08:15 PM
winters's Avatar
Just read it in Feb. issue of motortrend Re. truck of the year
Old Dec 31, 2003 | 08:26 PM
blitzkrieg's Avatar
Take it with a grain of salt until confirmed - they also said the Lariat has real wood trim...
Old Dec 31, 2003 | 09:41 PM
roboots21's Avatar
I would also like to know if this is true, cause if it is I would like to know who the genious was that thought of a non-serviceable transmission/
Old Jan 1, 2004 | 12:17 AM
AjRagno's Avatar
The new F-150 transmission is indeed sealed.... Not even a dipstick to check the level. I suspect it is similar to the 5R55E in the Explorers. If so, you need a machine just to check the fluid level
Saves money on assembly if there's no dipstick and brings in HUGE $$$ if you need a dealer just to check the fluid level and condition
Ford =
Old Jan 1, 2004 | 12:30 AM
bikelover's Avatar
Well, my 04 Screw 5.4 with the four-speed auto has a dipstick on the tranny, and upon this dipstick are inscribed the words: Trans Fluid.
I must have a different tranny than some others.
Old Jan 1, 2004 | 12:16 PM
Curmugeon's Avatar
Yep, a quick check of the Ford brochure (no need to lift my hood) has two 5.4 engine photos CLEARLY showing a tranny dipstick on the passenger side of the engine.
Old Jan 1, 2004 | 02:22 PM
PC Poppy's Avatar
I got a dipstick.
Old Jan 1, 2004 | 02:34 PM
vocabulaic's Avatar
Well, pending how you read it - they're right. It has "real" wood trim... meaning that it's not stickers... (go check out other competitors, and their trims are sticker-packages, not actualy molded plastic and all)...
Old Jan 1, 2004 | 03:02 PM
blitzkrieg's Avatar
I just checked my '04 5.4 FX4 (High Torque tranny).
Its got a removable tranny pan and a dipstick marked "Trans Fluid - Use Only...", so its just as serviceable as any automatic tranny I've ever seen.
I think somebody got their wires crossed on this information.
Old Jan 1, 2004 | 06:06 PM
Silvern's Avatar
My 5.4 FX4 has a Trans dip stick also.
Old Jan 1, 2004 | 07:38 PM
johnboy2's Avatar
They probably meant it requires no service.
The 4R100 gets a fluid change evary 30,000 miles.
The others (4R70E and 4R75E) only need the fluid checked.
Ford says they're "lubed for life"
Most of you will choose to have them serviced, but the maintenance schedule doesn't require it.
