trim problem...
Old Dec 23, 2003 | 09:27 AM
bmcqueen's Avatar
trim problem...
The small gas cap door on my 150 has lost it's tension and now won't stay closed...any ideas on how this little sucker works...can I fix it myself?
Old Dec 23, 2003 | 09:38 AM
geo036's Avatar
In a related note...does everyone elses filler neck look as if its missing the little metal "flap" that covers the neck hole when the nozzle is removed?
Old Dec 23, 2003 | 09:39 AM
Guigster's Avatar
There is no flap. It's not on Dodge Rams either, so it's not just an F-150 thing.
I knew when I first saw the plastic gas tank door, back in August, that there was going to be an issue.
Old Dec 23, 2003 | 10:47 AM
J-150's Avatar
warranty work.
Old Dec 23, 2003 | 10:57 AM
Superdog's Avatar
yep, feels pretty flimsy. and as thirsty as this truck is, that door gets used alot
Old Dec 23, 2003 | 02:59 PM
Mr.McFeely's Avatar
Mine broke in the same way. Dealer tells me its warentee work, but they need to hold the truck a day to get it done in their body shop. Looks like it's held on with three screws to me, not sure why it should take more then 5 minutes to replace it.
I found if I swivel the tie that holds the gas cap to the truck, it can be used to keep the door closed. (tie is tied to the door). This is a temporary solution until I can find a day to hand over my truck.
