7.5 Quarts???
Old Dec 22, 2003 | 01:47 PM
mikey88's Avatar
7.5 Quarts???
Just got my first oil change at 2000 miles and they said it took 7.5 quarts. That seems like alot to me??
Old Dec 22, 2003 | 02:06 PM
NotBigEnuf's Avatar
Why so soon? 2000 miles? isn't the recommended change at 3000?
Old Dec 22, 2003 | 02:12 PM
Jackslapp's Avatar
This isn't your daddy's 5.4L. The new ones hold more oil......
Old Dec 22, 2003 | 02:20 PM
geo036's Avatar
Actually I think recommended @ 5,000 on the 04 5.4
Old Dec 22, 2003 | 02:21 PM
freddy40's Avatar
seems right to me, i changed ours at 3500 miles and two things I noticed. 1 - took more oil 2 - no shavings
freddy
Old Dec 22, 2003 | 02:23 PM
NotBigEnuf's Avatar
that is the way it should be!
Old Dec 22, 2003 | 02:52 PM
horkn's Avatar
hell, i will change my oil after 100 miles the first time. then 1000miles, then normal intervals after that. oil is cheap, and clean oil is the best oil
Old Dec 22, 2003 | 04:00 PM
bikelover's Avatar
I've done two oil changes on my Screw, the second one just yesterday. The manual says the capacity is 7 qts, so I put in 7 qts exactly, and the dipstick shows the oil level to be several millimeters below the top line, so it probably could take another half quart or so.
FWIW my 5.4 engine has almost 8k miles on it, and uses zero oil.
I'm using the Motorcraft 5W20 oil and a stock 820S filter, both of which I get at Autozone.
Old Dec 22, 2003 | 04:24 PM
mikey88's Avatar
I decided to do it early for the first oil change. It seems faster now???
Old Dec 22, 2003 | 05:01 PM
horkn's Avatar
gotta love new oil
Old Dec 22, 2003 | 05:24 PM
Curmugeon's Avatar
Large oil sumps, e.g., the 5.4's 7 quarts=improved engine cooling and longer oil life. Racing engines carry 20 or more quarts. My neighbor's wimpy V-6 Dodge has a 4 qt. capacity.
Old Dec 22, 2003 | 09:08 PM
BigSky's Avatar
I also read that it takes 7 quarts. I had mine changed at 300 miles. The sooner the better the first time. It makes sense that more oil is better for the engine except maybe warming it up in the winter months.
Old Dec 23, 2003 | 07:37 AM
kidtriton's Avatar
if it calls for 7qts, and the level on the dipstick isnt all the way to the top line, i would leave it there. That top line is marked MAX, instead of FULL, im pretty sure. If that is the case, then what ford means is definately dont go over the top line. (because the crankshaft can actually start slapping oil in the pan, causing vibrations and less fuel mileage) So what im saying is that if you put the specified amount of oil in, and its anywhere between the MIN and MAX marks, you're good to go.
Old Dec 23, 2003 | 09:46 AM
Supercrew04's Avatar
If over filled the pcv system does not work correctly, A little tip down forget to drain the old oil first...lol
I've seen people over fill them by as much as 3-4 quarts to the point where it will feel like its misfiring due to the fact that the pistons can't come all the way down.
David
Old Dec 23, 2003 | 10:49 AM
mikey88's Avatar
It was in between min and max with 7qts, but very close to min, so the tech decided to add another 1/2 quart. I had always heard too much oil was bad so I asked him if he was sure it needed and he said yes. I had the oil changed in my 99 f-150 one time and the idiot only put 5 quarts in it. I checked it three days later and it would not show on the dipstick. When I went and questioned him, he admitted the screw up. Guess it's best to do it yourself
