Rear Seat Removal?
Ok I think I have talked myself out of putting my amp behind the rear seat. The biggest reason is that I can't get the damn back off. I think I am going to mount it under the rear seat on the hump.
Pros: Easier Install, Can get to it whenever I want, ventilation, and easier to route wires.
Cons: Takes away from room under the seat (what would I put under there anyway) and not 100% hidden
Any thoughts???
Any thoughts???
Any thoughts???
Any thoughts???
Originally posted by Jamesdc1
I have a pdf that shows how to remove it.
Email me and I will reply with it. Don't know another way to post it.
Thanks, bishent@midwest.net
I found the pdf file to be of marginal benefit. Check out my gallery for pictures of the seat removed, the clips, notch, etc. I also show pics of my amps installed. I haven't put the sound deadening liner back in yet, but it will be notched out to leave the amps exposed. Without the liner and seat installed, man is it loud in the cab!!
Also, to facilitate easy seat removal, I taped the tabs open with electricians tape. Now to remove the seat, all I have to do is remove the center seat belt upper housing and the seat lifts out. I don't really see the seat clips being that important.
Hope this helps.
seat removed
Hope this helps.
seat removed
Wow! You dug up an OLD thread here!
The PDF you desire is linked in my gallery:
http://www.gordonmerrill.com/truck
