augh,not a water leak.
I was driving in the rain today and noticed some water on the passenger side armrest,after further investagation it seems that the doors are not closing tight enough. I checked the drivers doors and they were tighter,hope a simple adjustment can fix. Any one else had this problem?
i would think that you can just adjust the door
a friend of mine had a 2003 ranger and now a 2004 ranger and both of them have had this problem and both were able to be fixed.it was also his passenger doors that gave him trouble. i know a ranger and an f150 are 2 totally different trucks but i would think yours is adjustable just as his is.
just my .02
just my .02
I've noticed water on my armrests also. Initially, I was alarmed until I noted that when opening the doors some water from the upper door surround will drop down onto the door interior. Check the source carefully before assuming there's a leak.
I thought of that,so when i got home i slid over to the window and the seal was wet. Also you can feel the drivers door at the top on the outside and it is pretty much level with the cab,passenger side is not.
