My '04 Lariat Issues...
Old Dec 3, 2003 | 10:55 AM
wingn8ive's Avatar
Took my truck into the dealer yesterday for her 1st (free) oil change and a list of "new model adjustments" that were needed:
1. There is play (slip) in the drivers power seat. You can feel it slip backwards a bit when taking off from a stop.
2. Vibration in the rear end when accelerating from a start or in a turn. It’s usually noticeable in the morning, after sitting for a long period of time (a day or two).
3. Outside temperature display is incorrect. (PCM needs to be reprogrammed to the latest level, using WDS B27.10 or higher.)
4. Very slight pull to the right.
5. Slight vibration or shimmy in the steering wheel when applying the brakes, and occasionally noticeable under normal driving.
6. Audiophile unit seems to display text very slowly.
7. Outside panel vibration or rattle in the driver’s side door when closing.
I spoke with the Service Manager last night and she said that everything has been taken care of, except for #2 (rear-end shudder/vibration), which will be completed by Thursday. The Service Tech was able to duplicate the problem (after letting the vehicle sit for a while) and, apparently, the clutches in the rear differential need to be replaced.
Old Dec 3, 2003 | 11:00 AM
BrewMaster's Avatar
Re: My '04 Lariat Issues...
good to hear that the issues are getting resolved. are they going to put a new differential in or can they just change the clutches. did they tell you what was wrong with them?
Old Dec 3, 2003 | 11:10 AM
wingn8ive's Avatar
From my understanding, they're just replacing the clutches... not the entire differential. I could be mistaken, though, but I'll find out all the details when I pick her up.
Old Dec 3, 2003 | 11:26 AM
vocabulaic's Avatar
Replacing the entire differential would be a waste if it's just a problem with the clutch... They'll probably just take out the LSD that is in there and completely put in a new one.
Old Dec 3, 2003 | 11:47 AM
SilvrDrgn's Avatar
What do you mean by this? What text ???
Old Dec 3, 2003 | 11:53 AM
wingn8ive's Avatar
When RDS is ON and you select "SHOW NAME", the information/text that is displayed from the radio station seems to take a long period of time. So, lets say the artist and song are being displayed, some words may be missing due to the slow scroll of the unit.
Does that make sense? Maybe I confused the issue more.
Old Dec 3, 2003 | 12:15 PM
vocabulaic's Avatar
That's been discussed prior... It seems to be the closer you are to radio stations the faster it goes - slower when you're farther, and when in between mountains and the like... still unresolved however.
Old Dec 3, 2003 | 12:30 PM
wingn8ive's Avatar
our '02 Expy display works just fine, so that location thing doesn't hold water with me. Plus, if you're hearing the radio station, your location is fine... and you should see the text, too.
Old Dec 3, 2003 | 04:13 PM
ScottS's Avatar
I just bought a Lariat with Audiophile and it does the same thing. Any news on a fix yet?
Also having a hard time trying to adjust the sensitivity on the factory alarm system. It's too sensitive.
Scott
Old Dec 3, 2003 | 04:16 PM
BrewMaster's Avatar
i think you're right wingn8ive. the text signal comes with the audio signal so location should not make a difference. did they resolve this issue? i don't even look at mine it is so bad. not only does it miss words, but sometimes it will just put up gibberish and meaning less characters. it sucks.
Old Dec 3, 2003 | 04:34 PM
wingn8ive's Avatar
no update yet... I'll be calling the service manager pretty soon to see what the status is. I already miss driving my damn truck !
UPDATE:
For the vibration in the rear end, they soaked the rear differential clutches in friction modifier and put everything back together. They're on a road test now, to see if it reoccurs.
No word on the rest of the stuff, yet.
Old Dec 3, 2003 | 06:32 PM
BrewMaster's Avatar
wing, in the owners manual it explicitly says NOT to add friction modifier to the real differential. i don't know if soaking it counts, but you may want to bring that up with them.
Old Dec 4, 2003 | 11:29 AM
wingn8ive's Avatar
They called and said everything is fixed and my truck is waiting for me to pick it up. Will get it at some point today. I did mention that the manual said not to add friction modifier and they said that they obtained the fix for the problem from the hotline. So, I would assume everything will be fine with it. Hopeful anyway.
Old Dec 4, 2003 | 12:21 PM
BrewMaster's Avatar
for your own sanity (and proof if ever a problem) I would get a copy of that fix by fax and have it detailed in the service report that they put friction modifier in there. i know it is not unheard of, but you don't want to have it come back to bite you in the *** in a few years. glad to hear your baby is fixed. let me know what happened with the RDS and if it works now.
Old Dec 4, 2003 | 03:33 PM
wingn8ive's Avatar
OK, here's the deal....
I picked up my truck and here's what happened with these issues:
1. PROBLEM: There is play (slip) in the drivers power seat. You can feel it slip backwards a bit when taking off from a stop.
CORRECTION: Ordered a new seat track, ETA 1 week. (They never mentioned it was ordered... said it was fixed. Problem still happening.... I'll be calling about this one)
2. PROBLEM: Vibration in the rear end when accelerating from a start or in a turn. It’s usually noticeable in the morning, after sitting for a period of time.
CORRECTION: Soaked differential clutches in friction modifier overnight, reinstalled and road tested OK. (Everything appears to be OK, will know more in the next couple days. Details were noted on the work order.)
3. PROBLEM: Outside temperature display is incorrect. CORRECTION: Reprogram PCM.
4. PROBLEM: Very slight pull to the right.
CORRECTION: Balance and align front end.. center steering wheel. (Appears to have corrected the problem.)
5. PROBLEM: Slight vibration or shimmy in the steering wheel when applying the brakes, and occasionally noticeable under normal driving.
CORRECTION: Same as #4.
6. PROBLEM: Audiophile unit seems to display text very slowly.
CORRECTION: Deemed as normal operation.
7. PROBLEM: Outside panel vibration or rattle in the driver’s side door when closing.
CORRECTION: Deemed a normal characteristic, as compared to another vehicle of the same type.
Also, they completed the oil change and used 7 qts of 5W30. I was under the impression that 5W20 was to be used.... is this the case or does it matter? I think I'm gonna mention this, as well.
