Changing Oil.... Drip Tray
I changed my oil last week. Didn't use anything under the filter, so oil did run all over. My old 150 5.4 had a nice little sheetmetal guide under the filter to direct the oil into one place, but not so on this new 5.4. I believe that, next time, I'll use a baby diaper under the filter to absorb the oil that comes out of it. I use this method on my little Miata, and it works pretty well, keeps things cleaner under there.
The first gush of oil from the filter when loosened drops straight down into the pan (if y'all use one). The oil cleanly missed the cross member...the rack and pinion is far forward of the filter. However, I really miss the ease of changing the filter on my '97 F250 (LD) 5.4...it was located in the driver's side wheelwell just ahead of the tire. Really neat...could change the filter without having to crawl under the truck.
2004 Screw 4x4 with tow package
On these models, where do they locate the oil filter? I too love the ease of changing the filter on my 98 F150, it is nicely tucked inside the front bumper.
My CrownVic is not as easy.
The oil filter on the '04 F150 5.4L is located on the lower left corner of the engine just below the camshaft pulley...it's angled slightly toward the passenger side fog lamp...a little tough to get a wrench on or align the filter to the gasket facing.
