Trouble getting key out of ignition
Old Nov 21, 2003 | 07:48 PM
Dondo7's Avatar
After turning the Truck off, I can't get the key out ! I have to restart the truck and of all things, back it up a little bit, pull forward, turn it off and the key will come out. Irritating to say the least
'04 Crew 5.4
Old Nov 21, 2003 | 07:54 PM
MARSHALL1225's Avatar
MY DAUGHTER HAS HAD THIS PROBLEM WITH MY TRUCK A COUPLE TIMES.I TOLD HER TO MAKE SURE SHE HAD THE SHIFTER ALL THE WAY UP IN PARK AND SURE ENOUGH SHE PUSHED IT A LITTLE BIT FORWARD AND GOT THE KEY OUT.
MR
Old Nov 21, 2003 | 09:22 PM
rdotson's Avatar
I have the console shifter and mine has done that a couple time.. just need to push the shifter another quarter inch and it work.. My guess is this could be adjusted out.
Old Nov 21, 2003 | 11:04 PM
Dondo7's Avatar
Fiddling with the shifter was my first thought too but it didn't work. It just did it to me several minutes ago...'had to back the darn thing up, then forward and out it came...whatever
Old Nov 26, 2003 | 11:24 AM
Guigster's Avatar
I did the same thing when I first got it. I have the steering column shifter, and it wasn't completely in Park when I shut off. I was getting pi$$ed. Then I pushed the shifter all the way and the key came out.
Old Nov 26, 2003 | 12:19 PM
BrewMaster's Avatar
your next option would be a hack saw. good thing you found a better solution.
mine does it when the shifter is not all the way in park. it's only happened 2 times in 2 months. i blame myself, not the truck for that one.
