Auto Temp. Control
Mine does that also wierd eh
hey if your listening to the radio and turn off your truck remove the key does your radio stay on mine does .
i havn`t done a test too see if its some time delay action or not .
But this truck sure does turn heads and unbelieveable waves from older model screw owners hehe
yeah, it says AC even if it is heating. i guess their reasoning might be that it is conditioning the air even when it is heating it. most people think cooling when we think of AC. i guess they are using the label a bit liberally. whatevers, it keeps the temp right, that's all i know.
Re: Auto Temp. Control
Originally posted by MARSHALL1225
IS IT NORMAL FOR THE A/C INDICATOR TO COME ON WHEN I HIT THE AUTO BUTTON FOR AUTO TEMP CONTROL
MR
MR
Yes, AC has gotten some confused, AC is air conditioning - not air cooling like some believe it to be. It is still "conditioning" the air regardless of whether it's heating or cooling.
Same thing happens on mine. I think it is because we haven't had any really cold temperatures here yet. I'm waiting to see if it happens when it is in the 20s outside.
I believe that in all vehicles, the A/C comes on when you turn on the defrost if the outside temperature is above a certain level. The A/C takes the humidity out of the air and defogs the windshield faster.
The A/C indicator & compressor will come on until the outside temperature reaches approximately 34F. This is normal operation and works the same way on the manual systems. The compressor runs in all modes except "floor" and "vent" although you can't see it since there is no indicator. Now if they'd just put the word "Auto" and the "Defrost" symbol in the display area. You CANNOT see those dinky little indicator lights for these two modes in the daylight.
