5x7 vs. 6x8 speakers?
the gap is very minimal, if any. i'll be putting sound deadener behind the speaker and around the mount to minimize the vibration and also get rid of any unseen gaps.
my cross overs were too large to fit in the door handles. i ran new wires through the door boot and wire-tied the cross overs to wiring harnesses in the cab. i disconnected the boot by the cab side to help fish a line through that i used to pull the new speaker wires. although time and patience consuming, it wasn't difficult at all. the passenger side is more difficult due to the fuse panel being right there, but i hooked the wire and pulled it behind the panel (there's about a 2 inch gap between the back of the panel and the wall).
I have the rears and "how-to" write-up in my gallery.
https://www.f150online.com/galleries....cfm?gnum=3359
Re: Daneo2
Originally posted by bfab
Thanks, I saw that already you did a great job on that I wanted a picture of the fronts
Anyone know how to remove the tweeter from the component system in the front doors?
Does it pop out the front using a pry tool?
Do you have to take the door panel off?
Thanks!
By the way, I purchached 2 sets of the Speaker Wiring Harnesses
from BestBuy for $5.99 a set, and they are a perfect match.
They are called Metra TURBOWIRE AUTO STEREO WIRE HARNESS SYSTEM
FORD SPEAKER ADAPTER
BestBuy Part# 72-5600
or
www.metraonline.com
Thanks!
or
www.metraonline.com
you can get adapters at www.mjmautoinnovations.com/speakeradapters
you can use a 6 1/2", or a 5 1/4"
This is a bump for info...
Thanks!
or
www.metraonline.com
Thanks!
or
www.metraonline.com
