Noise
I got a new Black 04 Lariat 4x4 with the stick, a moon roof and the audiophile sound down in Garland, TX. They treat you well. The truck runs great, feels like it is nailed to the road, but with the extra 600 lbs you do not notice the increased horsepower. (I had the same model in an 01).
Since the first day it has made a noise which is most predominant when idling in gear. The dealer said it is the bigger and wider fuel injectors. He even took me to the lot and started another new one and it appeared to make the same sound. It sounds like tappets. Anyone else have a similar experience?
I heard it...
I went and test drove a Lariat SC yesterday. The salesman was walking around blabbing and the truck was running. I had the doors open and was lookingat the interior under sun light and as I was bent over looking under the seats and things i noticed the sound was more pronounced, sounded like a tapping.. I dared not ask the saleman about it for fear i would hear even more stuff I already knew...the best way to see for yourself if that noise is injector noise is to take a LONG thin shank screwdrive, place the screw end on the injector and put your ear next to the plastic handle end, you will hear the tapping in the plastic if it is...that is an old school way of checking but it has worked every time for me...if you don't hear it, thenyou have an injector problem..lol hopefully not on a new truck though.
later
later
Yes beastboy, you have a point but the one I most recently witnessed didn´t make a noise either until after some miles. I like the explanation you were given, although much more involved, then what they told this customer. Makes more sense and means they might need to do some changes. Instead of having to drive it and wonder. I saw it back in service yesterday so i will have to go and find out what became of it and tell them what you were told.
Well, I took my truck to my local mechanic who has served me well in the past when I have had issues with Ford. He said the ticking really was the fuel injectors above the engine and not the valves in the engine. He said that BMW had a similar problem a few years ago and I should not worry about it. This is the same explaination I got from the Ford service manager.
I am really to call this good
Originally posted by CometFlash
With all this talk of ticking noises from the 5.4's, it makes me think it might be best to wait for the '05's. I thought this truck was supposed to be the quitest truck on the planet, Ford?
Re: Noise
"With all this talk of ticking noises from the 5.4's,
be the quitest truck on the planet, Ford?"
The truck is great inside. Much less wind noise and you cannot hear the ticking. You only notice the noise when you are listening by putting your ear to the wheelwell.
Well, I now have 86,000 miles on it and, although it runs great and does not burn any oil, the ticking noise is louder. Yesterday, I was idling along side of a parked car and it sounded real loud with the widows down. Still love the truck, though
