Is my transmission shot?
Old Nov 9, 2024 | 03:51 PM
tacomaguy20's Avatar
I was driving my 2002 ford F150 automatic today and all the sudden when I hit 2nd gear my vehicle felt like it was in neutral. RPMs would spike when I pushed the gas and no power. If I let off the gas and gave it a minute, it would seemingly go back into 1st & it would drive again. The vehicle does move forward on idle but I am getting no reverse (not even an idle) and there are no dash lights indicating a problem. I have a cheap Bluetooth OBD scanner that connects to my phone and it told me there were no diagnostic codes. I managed to get the vehicle home but as I sped up (hardly at all) it would seemingly slip out of gear and then slip back... it was really intermittent. So I'm thinking it's the transmission but since I have no codes to go by I thought I'd just ask everybody here on their thoughts in case it's something else I'm not aware of before I pay to get it towed to a shop. I'm not sure it would make it there driving to be honest.
Additionally, if it's the transmission, would it be worth fixing on a truck this old?
Old Nov 9, 2024 | 06:33 PM
If the OD light isn't flashing, there probably aren't any codes. This does sound like an internal transmission issue, rebuild time.
Old Nov 10, 2024 | 08:07 PM
Thanks, I bought the truck for $2750 several years ago. I'm glad it lasted me this long but it was kind of a surprise because there didn't seem to be any warning that the transmission was going out. Thanks for confirming but I don't think I want to spend 2 grand or more for a used/rebuilt transmission on a 22 year old truck
Old Nov 12, 2024 | 07:36 PM
jimbo74's Avatar
5 Year Member
have you checked the trans fluid level or condition yet?
Old Nov 12, 2024 | 07:45 PM
Yeah it was full and light pink ...so it looked good. I had a flush not too long ago as well.
Old Apr 3, 2025 | 01:38 PM
Grounder01's Avatar
Flushes can create problems, loosening dirt that can break loose and then get in valves and all the small components.
Old May 29, 2025 | 01:22 PM
Fordtech12's Avatar
Have you ever drained/refilled the trannie fluids? It could be a TPS sensor going out, I heard of symptoms where the TPS could malfunction causing that type of thing.
Old May 29, 2025 | 03:02 PM
Fordtech12's Avatar
BtW, have you checked the PNP switch, that can cause issues, I recall there was a bushing the cable attaches to in my previous ride that links to a shifting wand, I'd check the cable, linkage, and bushings too
