Why does this battery cable cost so MUCH?
Old Feb 21, 2023 | 08:23 PM
oldpops's Avatar
I have a 2001 F150 Super-crew (5.4L, auto-trans, 2 wheel drive) that has always gives me trouble whenever I change the battery. We've got it started/running again, and in an attempt to remove the possibility of dirty connections and/or a frayed or broken wire (hidden by shielding), I've decided to start changing out everything I can, starting with the battery cables. I did an internet search for the positive battery cable (Ford part Number: 2L3Z-14300-AA) and it comes up for an average price of between $400 to $500 dollars??? I understand that they don't make these cables anymore because our truck is over 20 years old, but $500 bucks for a battery cable? What is so special about the positive battery cable for this truck? Can't I just make my own if need-be? Or is there something special on this cable that is required? Is there an alternative, and less expensive alternative that can be used?
Thanks in advance for everyone here who offers help and advice!
Old Feb 21, 2023 | 09:22 PM
Old Feb 22, 2023 | 09:38 PM
Typically the Ford cable is part of the engine bay harness, and not an independent power cable.
Can also use newer Ford Edge cable ends/battery terminals. and can crimp on your own additional cable ring terminal if needed.
https://www.tascaparts.com/oem-parts...al-bt4z14450aa
here's my video rebuilding cables on a 1994 Ford Lightning
