No crank no start tried everything
Old Oct 30, 2022 | 07:42 PM
Riley,m's Avatar
dosnt start its giving code B1352 (ignition key in circuit fault) I went an got a new ignition switch didn’t fix the problem and tested the ignition lock both good so I took the starter off and tested its working as should I think, is the starter supposed to just spin or come out and spin? I don’t know what to test now any ida how to get rid of this code. Like all fuse, ground wires good
Old Oct 30, 2022 | 07:55 PM
Do you have an aftermarket remote start system in your truck?
Old Oct 30, 2022 | 08:19 PM
Riley,m's Avatar
nope everything is factory
Old Oct 30, 2022 | 08:22 PM
projectSHO89's Avatar
It helps if you identify exactly what you're working on...
Old Oct 30, 2022 | 08:26 PM
Riley,m's Avatar
i mean nothing just trying to get it started looking for what I should get it’s a no crank no start. Okay I guess I’m trying to find out what code B1352 is and how to fix it
Old Oct 30, 2022 | 08:47 PM
He wants to know DETAILS about your truck........
We can assume it's a F150, but we need a bit more than that.
Old Oct 31, 2022 | 12:36 AM
J_P's Avatar
J_P
5 Year Member
Could be a weak battery, a faulty starter or a damaged section on your fly wheel.
Old Oct 31, 2022 | 04:05 PM
A B1352 is not going to cause a "no crank" issue. It's a secondary issue on whatever it is that you're asking about (which you failed to identify even after being told that information is needed).
Old Oct 31, 2022 | 04:15 PM
If I'm going to throw darts I'd look at the MLPS, which is the neutral safety switch. Move the shift lever slowly through the ranges while holding the key to START.
Old Oct 31, 2022 | 07:46 PM
Could be any of a half dozen things.
Pretty pointless to suggest anything without even knowing what is being discussed.
Old Oct 31, 2022 | 08:51 PM
Only thing I could find is that this person has a: 2003 Ford F-150.
Old Nov 1, 2022 | 04:51 PM
Veteran: Army
and wants advice without providing the basics
