No crank no start
No crank no start
Hello I have a 2003 Ford F-150 it has a no crank no start every time I go to start when the key gets into the acc/on position the starter engages but it’s like it’s spitting it out and won’t stay engaged I’ve clean all connections and tried to jumper the car and put a brand new battery into anyone know what my problem is?
I’ve tried to jumper the starter dose nothing but spark
[QUOTE=ManualF150;5278500]What do you mean by "spitting out"?
It’s how the starter sounds it literally sounds like it engaged but spits it out and won’t stay engaged. The starter engages for a split second.
Make sure the truck is in Park/Neutral, parking brake set, turn the key to on, go under truck with a screw driver and jump the starter. See if the truck starts.
Make absolutely sure the truck is in Park/Neutral and the parking brake set before doing this.
I just had mine fixed. No crank no start. Battery was good, the starter was good. The starter relay was good. I even bought another one just to be absolutely sure. No change. I disengaged the remote starter, nothing! When I turn on the ignition, everything lights up as should. After a day & half, I gave up, towed it to brakes plus. They said something about the PATS. Turned out the key chip was going bad. They bypassed the security system & was able to start it. They had it diagnosed in 45 minutes. $100 well spent. Luckily, I had another key. It works every time! I don't have to go the dealership and buy new keys and reprogram it!
I thought I share this cos it had me stressed beyond FUBAR!
