Need some help... im a newbie here
Old Aug 7, 2022 | 08:00 PM
Chrislyn's Avatar
I have a 1997 f150 ..... no crank no spark ... changed spark plugs yesterday still nothing .... however noticed a plug that I'm not too sure where it belongs could it be to the crankshaft sensor... maybe the harness???? Please help tia ..... added some pics
Old Aug 7, 2022 | 09:39 PM
No crank - as in you turn the key and nothing happens? Or - does it turn over but just not start? Which engine? How do you know there's no spark?
Old Aug 8, 2022 | 06:30 AM
Chrislyn's Avatar
it turns over just doesn't start.. 4.6 L V8 ..... it seems there is no spark..... spark plugs were very dirty it was time to replace them so I did. Checked all fuses and no codes come up
Old Aug 8, 2022 | 10:24 AM
Have you used a spark tester? Do you have fuel pressure?
Old Aug 8, 2022 | 11:06 AM
Chrislyn's Avatar
yes to Spark tester and yes there is fuel pressure
Old Aug 16, 2022 | 05:15 PM
JCR 56's Avatar
How much fuel pressure did it have? It needs at least around 28lbs. to start.
Old Aug 16, 2022 | 05:28 PM
Roadie's Avatar
How did you check the codes? with a reader? If there is a P1000 code your computer may not be getting power. My PCM relay was bad causing my 02 to intermittently crank but not start.
