looking for knowledge/answers
Old Apr 4, 2020 | 05:53 AM
JustTryIng's Avatar
I have recently been handed down a 1998 Ford F150 2WD stock I’m looking into buying 20 X 12 -44 offset beast gloss black Rims with Rbp-repulsor M/T RX (33X12.50R20LTQ) and I’m buying a 3 inch body lift all together, I come to this thread to see if with that 3 inch body lift will it fit those tires and rims.
Thank you for any help or advice
Old Apr 4, 2020 | 10:32 AM
2wd or 4wd?
Old Apr 4, 2020 | 01:19 PM
JustTryIng's Avatar
JustTrying
2wd
Old Apr 4, 2020 | 01:25 PM
jimbo74's Avatar
5 Year Member
Height will be fine, but you are going to rub with that wide of a tire
Old Apr 4, 2020 | 04:15 PM
JustTryIng's Avatar
would getting wheel spacer help with the rubbing and or would the rubbing be major if I just trim the plastic under the truck?
Old Apr 4, 2020 | 08:02 PM
jimbo74's Avatar
5 Year Member
Spacers will make it rub worse. Realize those wheels are almost 2x wider than stock
Old Apr 5, 2020 | 07:42 PM
JustTryIng's Avatar
I see that. But even with three inch lift the probability of them rubbing is high?
Old Apr 5, 2020 | 09:30 PM
jimbo74's Avatar
5 Year Member
For 1, it's a body lift. And as I mentioned before, it isn't the HEIGHT that is the problem. It is the WIDTH.
Last edited by JackandJanet; Apr 6, 2020 at 12:07 AM. Reason: Removed Rude Remarks That Didn't Add to the Excellent Advice Given
Old Apr 9, 2020 | 04:49 AM
Fbird's Avatar
and the offset!!! the further OUT you push the tire......the MORE your going to RUB everything when you turn......PERIOD.
